BlueRose4247
- Sep 15, 2013
- 2
Hi...We have a 1983 Bayliner Capri - Volvo Penta AQ125A...bought it in May and this is the first summer we've used it...here's what happened:
Went out on the lake, ran fine, idled fine, planed fine...stopped and sat for half an hour; started back up, started fine but soon died; turned engine over, no fire; took off dog house, turned engine over, no fire; turned engine over again and lake water (not coolant water) gushed out of carb; took off carb cover, turned engine over and ten foot gyser gushed up and out of carb, then hydrolocked; got it home, pulled plugs, water squirted out of all four and water in oil...
Where to start? Symptoms appear to be a cracked block...all four cylinders with water, gushing out of carb, water in oil and pan.....any thoughts...help!
