LaDawns money pit
- Aug 13, 2013
- 19
Well I'm new here, my name is Ladawn and would like to do repairs on my boat.
Here's what happened. The end of last year I had the gimbal bearing replaced and everything looked at. This year was not able to use the boat much, but last time out rattle and vibration. I used this site to remove the outdrive and water in the bellows and the u-joint and shaft are rusty. I only put maybe 10 hours since the repair. The u-joints are sealed on mine so I cleaned them back up. They have no play and very smooth, so I think no water got to the needle bearings. The shaft has some pitting, will it be ok to re-use them. I can't find any damage to the bellows, so how did the water get inside. Gear oil is perfect with no water. I called the mechanic and he said it wasn't his problem but he would fix it. The price tag of 2,800 OUCH. I want to find the issues and fix it myself. I know he did not replace the gasket on the pivot or O-rings on the shaft.
So with all that said can someone please help.
Thanks for your help
Ladawn
Ladawn
