zell66
- Jul 6, 2007
- 211
I have a 1982-83 Bayliner 195 with a AQ 125 4cyl. Volvo engine and a Penta 270 out-drive. I have a electronic trim and after I trim the lower unit down and run around lake it will not trim up or down (tried doing this when I was trying to get into sand bar). It is locked in place even though throttle is in neutral and engine off or on. I can manually release the lock and lift lower unit by hand but using switch nothing happens.
I have taken cover off of relay and switch cover and heard a click and trim worked fine. it seams if cover is to tight or lose trim does not work. Any ideas of how to fix it? Looked on line and all they sell is whole trim unit, not just cover???
