soverign33
- Aug 20, 2013
- 1
Was recently left at sea with a steering fail. Wheel would not turn more than a couple of inches. On inspection I found that the only loose belt was the one connecting the alternator to the pulley. Does that pulley also enable the power steering pulley to work? Neither the v belts or the alternator pulleys were turning under power. A friend then came on board and forced the steering wheel hard until it moved, and then went very slack, it just spins now (but still no steering) Has that now also broken the steering cable or is it the steering head that he broke?
Many thanks
Many thanks
