Bert Bergen
- Mar 8, 2012
- 6
Need help from a Volvo Penta outdrive expert. I put a Perkins diesel in my 32 food Alcan aluminum boat which has a VP 280 outdrive. The gear ratio is 1:61. I have the largest prop available which is still not large enough to use the available power of the diesel. My only option left is to find a lower gear ratio which will fit the 280. Volvo made some 270's, the 270E and 270TE with lower gear ratios plus a 280E with a 1:45 gear ratio. All of these gears are quick change as per the information I read. My question is would these quick change 270 gears fit into a 280 and where would I find one. Thanks for the help.
Bert Bergen
Bert Bergen
