Just purchased a used boat with a Volvo Penta 5.7GL. The engine runs really well however I noticed the voltmeter was showing almost 18v at idle. With the engine running I checked the battery with a multimeter and it it showing 14.92, so I don't believe it is the voltage regulator, could it just be the gauge? The other issue I am having is the the tachometer, it fluctuates from 1000-2500 then at some point will just drift up to 6000 and stay there. This all happens while the engine is in a smooth idle. Finally, the trim works fine but the indicator does not respond, is there an way to check if its the gauge?
Thanks everyone for the help. I am very excited to own a boat but want to get these items corrected so I have better situational awareness. We have never owned a boat so I want to have as much information as possible especially with the engine performance.
