Can anyone out there advise me as to how to check that the timing belt on my Volvo Penta AQ151A has not slip a notch or two? I am concerned that the timing between the camshaft and the crankshaft may be out slightly and want to check that they are in synch. I was told by a marine mechanic that the rubber belt could slip a notch if the engine has backfired. The reason I need to check is that I have to turn the distributor all the way one direction just to get it to 6 degrees BTDC. Yesterday, I installed an electronic conversion kit to replace the old points system. I have a nice spark at all the cylinders and there is plenty of gas coming out of the carbs, but the engine won't start now. With the distributor completely turned one direction, the same as I had it with the old points, the engine barely makes an effort to try and start (and I mean barely). When I pulled out the plugs to have a look at them, they are wet and do not show that they are burning any fuel. But with the spark plug out (still attached to the high tension lead) and grounded, I get a nice spark, between the gap, when I turn the engine over. Any suggestions?
