Trying to start the boat for the first time this year in the driveway. tried to start it but battery was dead. went and bought new battery, hooked everything up, all electrical worked (sinks,blowers,lights,etc). then I tried to crank the engine and it just clicked like a dead battery for about 2-3 times that I tried to start it. then on the 4th time, I heard a louder single click and then nothing works (no blowers,lights,etc). thought the battery might have been bad but its not. waited a few days and checked the battery, registered 12.6 volts on the meter. so I hook it up again to the boat and test, still 12.6 volts. then I try to start the engine and I hear the loud click, and nothing. I check the battery and it is now registering 3.9 volts. if I disconnect the positive lead on the battery and recheck, its back at 12.6 volts. is this a short? bad starter? tripped breaker? bad connection? seems like if I wait a day, whatever it is resets itself and it will try to start but then the click just comes back and everything goes out.
any help would be greatly appreciated!
