Forgive me for I am new to boating.
I have a VP 5.0GL with a DP-SM outdrive. My raw water pump is leaking and I have a new unit to replace the leaking one. Question is the boat is in the water and I want to replace it without pulling the boat out. As far as I can tell I have no seacocks to isolate the pump. I assume that any water in the hoses that are above the water line will drain to the bilge and will not be a continous flow of water while I have the pump off. Do I need to prime the impeller so I don't run it dry when I first fire up the engine?
I appreciate any help/suggestions you have.
