homeyrocks
- Jul 22, 2013
- 1
I just found some power steering fluid in bottom of boat. After looking at power steering lines no leaks found. I found when moving the steering wheel back and forth fluild is coming out of the actutor at the ram that comes in and out pushing or pulling the steering cable. I can see fluid squeeze out around the rod. Is there a retaining nut or something on the end that just might be loose. Or is it the seals and the unit has to be replaced?
