Can someone tell me how high the timing marks go on a 1996 5.7 Volvo GL? I know they are in 2 degree increments, and I can see the groove demarcation between ATDC and BTDC, but there is a little bit of corrosion on the first few markings of the shaft making it hard to see. I can see the LAST mark for BTDC on the shaft, so I can count backwards from there if I knew what the final marking was...Is it 12 degrees? 10 degrees? I need to time to 8 degrees BTDC.... Thanks!!
Steve
Steve
