AMMO DAWG
- Aug 3, 2012
- 226
I got all the crud off my transom shield, new paint, new parts and ran into a snag on reassembly. As I'm putting the steering fork assembly back on the transom shield housing I seem to have two large washers that go on the bottom of the steering post below the O'ring. My manual makes no reference to them and any online schematic I look at shows the O-ring only. Want to get this right because once I tighten the steering arm on the post it's a bear to get off again. Attached some pictures, if someone with more experience on Volvo transom shield assembly could shed some light I would be grateful. I know the thrust washer goes directly under the steering arm, these two washer are much larger. Thanks in advance.
