Good afternoon,
I'm a first time boat owner having difficulty with my 2002 Reinell with a 5.0 liter Volvo Penta throttle body injected engine. On the second trip out the engine would crank but not fire. I found the fuel pump to not be turning on. After reading some forums on this site I was able to do some diagnosis.
There is no power to the fuel pump while cranking. After locating the fuel pump relay I jumped terminal 30 and 87. This made the high pressure fuel pump run. I swapped the relay but that had the same results.
I believe the pump is good, but I have a power supply issue. My next step is to open the wiring harness to look for a bad connection or diode. Am I on the right track or not?
The boat has only 70 hours I have a hard time condemning a $800 fuel pump with out exhausting all options.
Thanks for your input.
