I just purchased this boat. At around 3000 rpm the the hose starts to swell and comes off. I have about 40 psi at the thermostat as well as the output of the raw sea pump. I can take off the hose to the riser with no change in the pressure. I can have the thermostat in or out with the same pressures. I have had the thermostat housing off. Looks ok but little rusted. had the circulation pump off to see if the block was full of sand but was ok. I have small bubbles going in and out of the raw pump. the vacuum reading goes from 4 to at most 9. I have done a leakdown test but every cylinder shows 20% leakage. I can hear it and feel it coming out of the pcv valve. The water level does not change when I am doing the test. I have flushed the lines. I took off the riser and found it rusted but flows with a water hose ok. I do get slag out of the manifold drain almost every time the hose pops off.
The prop looks like it has hit every thing but the lottery. I was told the engine was new with 30 hours on it. Seems to me it is a restriction somewhere but I am lost on this one.
