I have a 2003 Larson with the VP GL-B (4012085309) that I was having some dripping from the raw water/sea water pump. So I took off the impeller housing and first thing I noticed was that there was no sealing ring. Second thing that has me confused is that the bearing housing wasn't part of the pulley, as in not attached to the pump itself, it slid right off after I had pulled the impeller housing.
I have no slack in the shaft coming out and the bearing feels good and smooth. But everything I have seen for sea water pumpls for my boat show the bearing housing as actually part of the water pump. I'm a little concerned and looking for some pointers here.
Is this normal? I will take a picture here in a bit and post it.
