I have out of spec high fuel pressure on my 5.7GI-E, which is causing hard starting and rich running. I have gone through the Volvo Penta diagnostics which have lead me through the following steps:
Step 2, check fuel pressure, result was not in spec (80 psi vs 60), go to step 12
Step 12, disconnect fuel return line from fuel rail and check pressure again, result was within spec (60 psi), go to step 22
Step 22, locate and repair the restriction in the fuel return pipe.
So I reattached the fuel line to the fuel rail and disconnected it on the other end at the fuel pump. The result was the same, fuel pressure was within spec.
So, the restriction is in the fuel pump, not the fuel line. The diagnostic manual doesn't go any further so I'm not sure what to do other than try to disassemble the fuel pump to find the restriction. Just wondering if anybody else has experienced this and determined what the problem was.
Thanks.
5.7 GI-E (3869258 S/N 4012126825)
MEFI 4b (12584052)
Thanks.
MEFI 4b (12584052)
