Browndog801
- Jun 5, 2013
- 12
I have been getting water in the boat not a lot but when I would pull it out of the water it has more than it should. I checked the gimbal bellow and it had water in it. I have ordered a new gimbal bearing, bellow and a linement tool. The u joints had a little surface rust but feel like the are in good shape no play. I sprayed and wiped down with WD40 and they look fine. The problem is the bellow looks good I do not see any holes. Could this water be coming from water intake O ring by the plastic nut? The lower unit oil is good no water. Would this let water in the boat?
Thanks
Browndog801
Thanks
Browndog801
