I have a 2004 Glastron sx195 Volvo Penta 5.0 GL-E, SX-M drive. Last summer I had a problem with loud vibrations when turning, So it turned out to Be the gimbal and bellows, and the dealer blamed it on a crack around the outdrive from the previous owner, they said someone had dropped it. So it ended up costing me 900$ I really don't want to go through this again.
The dealer put some black sealant around where the "Crack" was, but it was done sloppy, anyway it doesn't seem like it's fully reliable, the Outdrive works fine now, I just don't want to go through that mess again.
I also looked at the records of previous owner and he had to replace the Gimbal and bellows also, Is this common on these Outdrives?
My friend has a baja w/ 496 Mercruiser and Bravo one, and he never has problems, he sometimes even uses the same oil from last summer for the present summer on the outdrive, I don't Know, I need Advice.
Pulling the outdrive Seems very complicated & I don't Have the right tools for that. any advice is greatly Appreciated
