josephsiracusa
- Jun 3, 2010
- 49
I filled up the drive with oil and when i put the drain plug back in i put the oring on the drain plug and than screwed it in. The way i believe i should have done it is put the oring on the drive than put in the drain plug screw. My question is. according to the way i installed the oring Is it possible that the oring could get caught on the thread while screwing it in or does it self adjust as i turn and adjusts to the pocket it sits in?
