Sorry this is probably a really dumb newbie question:
I have twin AQ205A with DP-A?s. I know there is a potential issue with the trim cylinders on one leg; the previous owner was ?honest? about that.
The boat was out of the water about 6 months ago, and at that time the PO decided to lock both legs in the down position. The boat came with a 2nd hand leg for ?parts? and he demonstrated on this. It LOOKED straight forward. ???
The boat is still another 6 months away from coming out again, but I?d like to know that I can lift the legs if needed. I?d also like to find out if the trim system works, and/or the reverse lock, so I know what parts I will need when the time comes.
Is there really a ?manual lock?? If so, is it easy to release? The legs are under a fixed marlin board, so access will not be easy, however if flicking this manual lock is as easy as he made it appear, it should be manageable?
