bluedevil99
- Apr 30, 2013
- 2
OK so I just purchased this boat and took it out on the lake. It did fine during one round about the lake and then we stopped and did some fishing. After this I fired it back up and started cruising around the lake at a no wake speed. After about 10 minutes I started to hear a whining noise and seeing some steam rise from the engine compartment. I instantly shut it down and limped back to the dock via trolling motor.
Upon doing some research I opened up and looked at the impeller. It was complete destroyed. Not a single intact paddle left. So I ordered a new one and put it in hoping that this was going to fix the problem. Well it did not.
I hooked up the earmuffs and ran the hose to it. It started right up but once again hit 190 and kept on going and started to steam. So once again I shut it down and checked the impeller again. Impeller was fine but there was not a single drop of water in the impeller housing.
I did some more reading and found that it might be air locked. So I opened up the reseviour and put water in it while it was running. It sucked the water right down with no issues but then after a couple of minutes it once again started to overheat.
So with my very limited knowledge I am beyond lost on what to do next. Any help would be more than appreciated.
