Hello iboaters,
I am a new owner of a 1995 glastron 175 ssv with a penta 3.0 gs motor . sx series trans. i am having starting issues. i been all over the web and can not get a answer to my problem.
Problem
- i am not able to start the engine and have it idle for any more then a few seconds, a few times after filling the carb bowl it would idle but then cut off when throttle was advanced. fuel wasnt getting to crab.
boat did sit since october with a full tank of gas, last time known of running, carb filter was gummed up, once fuel line an carb filter was cleaned she ran well (so i am told)
Currently
when it does start to idel its normally off of starting fluid then cuts off.
-i have verified fuel to the carb by cranking the boat with a fuel line disconnected at the carb, cleaned the carb, verified acclerator pump operation.
-plugs where changed, i did not change the cap nor adjust timing
- i noticed the fuel cut off poppet in the carb bowl does stick but a slight tap on the bowl it releases.(on the way to get a carb rebuild kit)
What else should i look at am ichasing the wrong path(fuel) should i look at timing? thanks for any help!
Problem
Currently
