Okieboatguy
- Jul 28, 2012
- 204
OK, I have searched the forums and found some information, but my OCD says I need more. I am planning on removing my AQ125 from my boat next weekend and want to make sure I am doing it correctly before I start. When looking at the coupling between the 270 out-drive and the engine I see a bell housing with 6 bolts. While looking at other like engines on youtube I noticed they all have the bell housing attached, so my first question is, will removing the 6 bolts be all that is required to remove the engine from the out-drive and the boat, or is there something else I need to do? OR, does the bell housing with the 2 "O" rings that fits into the drive need to come out with the engine as well? Second, since I will also be removing the out drive,and it was just completely rebuilt about 2 years ago, I was planning on trying to keep that in one piece when I remove it from the transom, is that also a good idea if I am able to remove the engine separately, or does the out-drive need to be dissembled from the transom shield? Sorry for the stupid questions, but I was not able to find a video or how to on the web or in youtube on the procedure, and since I am a picture kind of guy I can handle the info overload. Thanks for the help in advance.
