jamestheron08
- Oct 20, 2011
- 5
where are these two bolts?????? "5. Remove 2 side bolts on upper unit"
So for my bellows assuming everything goes right:
1. Remove shift cover plate
2. disconnect shift cable
Should only need to disconnect the vertical shift linkage.
3. Remove bolts in center of helmut lift helmut out of way
You will need a couple of 1/4 inch bolts to jack the pin out with
4. Loosen clamp on old bellows
Two bolts, two nuts
Two bolts, two nuts
