Joe Campbell
- Feb 9, 2013
- 4
So I am trying to replace the bellows on my boat. The outdrive is a volvo 270. I have removed the bolt from the helmet, disconected the shift linkage, removed the two nuts, and the two bolts. From what I have read on other threads is that the upper should pull strait up then back allowing me to replace the bellows, but the upper wont seperate from the lower. I dont want to pry or beat on it not quite sure how to get this apart so I can continue. Thank you in advance for you help.
