I Have had overheating problems this motor AQ 130 D. I Pulled the water pump today and the seal that goes against the block was in backwards. I am looking to buy a rebuild kit for this pump, seals, o-rings etc. I am not sure which kit I need. Also, there are no bearings is this pump, and some of the kits show bearings that come with the kit. Should there be bearings with this pump? and if so where do they go? This was how the pump was when i bought the boat and have had fits trying to figure out the overheating problem.
Any help this forum can give would be greatly appreciated.
Thanks
Thanks
