1995 Volvo 4.3 GS.
I'm sure anybody that has a carburated boat has this same issue. It's either the first start up of the year, or your boat sits for a few weeks, the float bowl in the carb goes dry, so the next time you get to the lake you need to crank the engine for a number of seconds to run the fuel pump to fill the float bowl. Then pump it and then go to start.
Question: My boat has an elecric fuel pump, has any body ever wired in a push button that you could push to run the fuel pump for a number of seconds to fill the float bowl in the carb prior to starting? Then I could just pump it, hit the key and the engine would turn over about 1 revolution and she'd be off and running.
My boat runs great, it just bugs me when I have to crank it for a while just to run the fuel pump to fill the float bowl.
Anyway, does anybody see any potential problems with this?
Thanks for your input.
