josephsiracusa
- Jun 3, 2010
- 49
hi, i have a volvo penta 275 sterndrive. i always change the oil in the outdrive myself every year also changing the drain/dipstick and air pocket screw orings and never having a problem. this spring the bellows needed to be changed as they both had holes in them. so i had a marine mechanic change them along with the gimbal bearing (came with kit) and had the mechanic also change the outdrive oil. i pulled boat out to service for winter and drained the outdrive oil noticing for first time milky oil. i noticed that the drain plug screw was not as tight as i usualy tighten it though it was snug. the dipstick, drain hole and air pocket screw ORINGS seemed to have no wear< i change them every year when servicing>. also where the orings sit seemed to be clean as oring lays flat. i did not notice and performance change either the 6 months the boat was in fresh water. questions....>>if bellows job was not done properly or bellows have cracks, holes etc...could water enter the drive through the bellows and mix with outdrive oil? if there is a leak, what are the steps to determine which seal needs to be changed? please help out thanks> btw the boat is a 1987 bayliner ciera 2450 with a aq225e engine and 275 outdrive........result i have done the pressure test and the drive holds 10 psi for aprox 15 mins and looses pressure after aprox 15 mins very slowly.....problem is i am not able to hear any hissing noise and identify where the leak is coming from? what should i do next. (please note i have not done a vaccumm test) could anyone tell me where this drive could leak water? i know the prop shaft seal and the upper gear housing seal? where else would it leak?
