I have a 4.3 gl in a 98 Larson. Last time I had the boat out it ran fine as it always has, I was pulling kids on tube and shut off boat to pull the kids in. When I shut off the motor it "dieseled" for a few seconds and died. That was the first time the motor ever "dieseled" when shut off. When I tried to start the motor it would not turn over, the starter would click or the spin but not engage. I got home replaced the battery with another one I had on hand and got the same result. Figured at this time it was the starter and replaced it. When I replaced the starter the motor turned over slowly for about 3-5 seconds and then nothing. I then changed batteries to one that is good and fully charged and the motor turned over for a few seconds, but it sounded that the starter was having to work extremely hard to turn the motor over. I know for a fact the battery used is good. Then after that nothing, the starter would only click or spin again. I then tried to turn the motor over by hand with a socket on the flywheel and could not turn it at all without using an extreme amount of force. I decided against trying to turn it over this way and break something making the situation worse. I am now thinking about pulling all the plugs and trying to turn the engine over to see if it will turn with no compression. I still have the original starter and am not convinced that it is bad since I have bench tested the starter and it appears to be OK. any ideas?
also no water in oil as seen when pulling dipstick
Did not overheat, at least guage was fine and alarm did not go off.
