Re: How to winterize a 2004 Volvo Penta 5.0 GL-E SX OUTDRIVE?
Thanks Don! One more question, Is it Necessary to Fill the whole engine back up with RV & Marine anti freeze? Like I said I have the 5.0 GL-E And this Is my First experience with Volvo, Also On page 87 It States A Process for 5.0 F series with Something about a heat exchanger Does that Include My Engine? and shall I Be fine if I Fog Carb, Drain all the Water From Plugs, Even the Hoses & Replace Impeller, Seals, Engine Oil, Gear Oil & Gaskets For the Winter?
It's in the owners manual, draining the cooling system of your engine is on page 86. How to do the rest of winterization is in the second link I gave you.
