Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
1986 Bayliner Capri AQ131A/275 ignition issue...
  • 1986 Bayliner Capri AQ131A/275 ignition issue...
    Hopefully someone can lend me a hand... Just ran my boat yesterday (9/30/12) after just replacing the ignition coil. Boat ran perfect for about three to four hours, then lost most of my power. I limped back to the dock to find two spark plug wires arching and replaced them, then let the boat sit for 20 minutes as I also refuelled. The boat fired right up. It then ran fine for about 15 seconds at idle, then died and wouldn't restart. I checked the ignition coil and it was completely dead no voltage to the ignition wire for the distributor, but had approx. 10 volts still coming off of the purple lead wire. Anyone out there have an idea as to what could be frying the ignition coil as this is now the second one? Points? Maybe the condenser? As far as dwell setting, I'm really not sure of it as I do not have a dwell meter. I thought maybe the arching wires could have been the cause too but why would it still restart for that moment after replacing them? Thank you very much to anyone that can assist me.
    Re: 1986 Bayliner Capri AQ131A/275 ignition issue...
    have you checked the shutoff button ?? (red button, its below the carb)
    • #3
      Yes I did and it was ok. The original ignition coil that was in the boat fried once before and that's why I had replaced it with a new one before that run on 9/30. I had thought that maybe the original coil was just old and worn out, or that it had gotten wet but I was wrong because the new one fried after 3-4 hours of constant run-time w.o.t. and idling.
      • #4
        Replace the coil, start the engine on muffs. Run at about 1500 to 1800 rpm and measure the voltage going to the + terminal of the coil.
        Red test lead of your meter on the + terminal of the coil, black test lead from your meter on a good clean ground. NOT the - terminal of the coil.
        Don S.
        Please, no PM's (Private Messages) regarding boat/engine problems.
        That is what the forums are for.
        Only forum/moderator issues will be answered in PM's.
        • #5
          Hi Don; thanks for your help. Well, replaced the coil today and now I have no spark out of the distributor; but I have power coming from the coil again. The positive terminal on the coil was reading between 8.75 and 9 volts (not running of course)... Think maybe the points are fried out also now?? There was roughly the same voltage coming from the coil to the distributor when the engine was cranking too.
          • #6
            Things that can cause coils to fail....Spark plugs with too large a gap, points not set correctly(dwell) and bad spark plug wires can all cause coils to fail.
            What happens with each of these causes is that the coil secondary voltages get so high that they have to discharge somehere and sometimes that means right through its internal insulation.
            You need to buy a dwell meter and set it(after changing your points) followed by timing your engine with a timing light.
            1998 Wellcraft Eclipse 24 Cuddy
            Volvo Penta Duo-Prop 7.4L "LK"
            2006 Sun Tracker Party Barge 21
            Mercury 90 4-Stroke FI
            "Common sense is not very common"
            "Failing to prepare is preparing to fail." -- John Wooden
            • #7
              Ok thanks a lot for the info. I'll replace what needs to be and check those causes. Do you perhaps know what the dwell is supposed to be set at? If not I'm sure it's on the internet somewhere. Thanks again.
              • #8
                Dwell 62 deg +/-3, timing 10 deg btdc @ idle.
                '88 Baretta Success 200
                Volvo Penta AQ260/275
                '96 Weeres Suntanner 24
                '01 90hp Johnson
                • #9
                  I would try to get it in the 62 to 63į range, takes a bit more work, but a lot better starting. With no choke, every little bit helps.
                  Don S.
