I'm hoping that someone can help me out a little here. I've got a Volvo AQ125A engine that was seized. Cylinder 3 rings rusted to the walls. I've taken apart the engine to just the block and am now going to start the rebuild. I'm wondering how to put the engine together in order to set the timing all correctly. In what position should the camshaft be when engine is at TDC? Where should timing marks be in relation to the marks on the timing belt?
