The motor had a bad starter removed starter and battery replaced starter and ignition relay. Went to start and got nothing but a click from the relay.I have power at the key switch, the yellow/red has power at the relay but no power out of relay when relay is jumped the motor will start, but when key switch and battery switch is turned off the motor still runs (w/starter still engaged) then somehow shuts down on its own. The purple shows power w/test light at starter, but the yellow/red does not when messing w/ key switch, engine turns over when starter is jumped w/screwdriver also, and since putting the battery back in, the gauges are going crazy and the trim does not work either... Im completly lost and desperatly need help...
