I am removing the aq130s from my boat, and am experiencing some difficulty in getting the engines to budge!
I have removed the outdrives, all mounts inside and removed the bolts from the clamping ring on the outdrive. I cant get the engine to pull back and out now, but there is a lot of corrosion around the clamping ring on the outside. Could this be holding it?
Does anyone have any tips on how to remove the clamping ring and the engine?
Thanks,
Louis
Thanks,
Louis
