sniper2320
- Mar 26, 2012
- 16
After installing the flamethrower coil and the pertronix ignation upgrade i found that i had to turn my distributor quite a bit counterclock wise what im sure is advancing it. I had to turn it all the way to the other side from when i had my points in to be able to get it to fire and run and be able to set the timing to 6deg..is it ok to have the distributot advance that much..??
There is no pinging or nocking when i rev it and it idles right at 850rpm and starts good.. As anyone had to do this?
i want to be sure befor i take it out on the waters and know that its not going to blow up...
