As the title says, Is it common for water to leak in between the flywheel housing and transom shield? Do these seals fail often? I went out on my boat Saturday afternoon. For whatever reason I always open the engine hatch when I've been sitting in the water for a while to see if water is leaking in. It's a habit. Sometimes the boat gets jarred kinda hard going over waves. The boat has never taken in water. Saturday I noticed a considerable amount of water under the engine. I pumped it out and I got to looking around and seen water coming in between the flywheel housing and transom shield a couple inches to the starboard side of the grease zerk for the support bearing. I drove back to the loading ramp which was about 10 miles and it didn't take on any water and I kinda figured it wouldn't. But once i started sitting there waiting on the trailer to be backed in I saw water seeping in on the port side a little farther down but no longer on the starboard side. I was thinking the ujoint bellow ripped for some reason. Once i got the boat out of the water I started looking at the bellows and didn't see any tears and got to looking closer and seen where the 6 bolts are and where the flywheel cover comes through. I kinda ruled out the bellows. So is it common for the seal to start leaking all of the sudden? Could it possibly be the bolts have backed off a little or even the engine tower starting to crush for being jarred around and the engine is falling forward a little. the engine towers that the front of the engine bolts to "looked" ok But I haven't looked real close at everything.
This is a picture of where it was coming in.
My boat is a 1990 Baretta Phaser 230 with a AQ231 and the outdrive says SP-CD trim
