Nickypoo
- Mar 21, 2012
- 287
Hi, I'm putting together this 270 outdrive for the first time since I got the boat from a neighbor.
I ran into a problem with the steering helmet. When I put it on, the bolt holes don't line up with the steering fork. It's almost as if the helmet is held too far forward.
The helmet is pushed on as far as it can go onto the upper drive unit. I don't see any way it could go on any farther or seat in a different position. The bolt holes are about 1/8" off on each side. The bushing on the helmet is completely seated. It doesn't seem like there's any play in the outdrive pivots.
So is it possible that this steering helmet came from a different outdrive, such as a 280 or something? It seems to fit on there well otherwise, it's just that the bolt holes don't line up.
I'm thinking the best solution is to have the existing bolt holes on the helmet welded closed and then drill and tap new holes in the correct position. What are your thoughts?
Thank you.
Thank you.
