jhanan
- Aug 4, 2012
- 9
So after de-winterizing my boat and checking the motor with the muffs on, checked the battery, and was ready to hit the water finally even know it already Aug!
I just seized my SX outdrive on my 1999 Regal LSR2100 with the 5.0GL. After reading the stickies here, it is clear I did not follow the proper annual maintenance instructions for the outdrive, I guess being a 1st time boat owner I left the outdrive alone while just taking care of the engine for every winter for the last 5 years.
Here was the scenario. Put her in the water and was backing out from the ramp with the drive up because very shallow ramp area - with Lowrance reading only 2.5 ft of water on Saratoga Lake it took forever to get out to deep water.
Outdrive is making this whining noise that I have never heard before! But once I was in deeper water, I dropped down the drive, and motored off - the noise stopped for awhile...but after about 15 min running 25 mph the whining noise was back and loud, so turned the boat around to head back to the ramp. Dropped speed down to about 7 mph and while was making the nasty whine sound was making progress to the ramp. However with about a mile to go, I stopped to give her a rest and when I shift back into gear - wham! Was still able to motor on, but then I stopped again and decided to try reverse - bad idea - it seized hard when I put it into R - killed the motor, jammed the selector. I was able to get her back into neutral after awhile. I just to try once more put her in gear and killed the motor. Prop stuck solid. So lake was busy (Friday) and I hitched a tow back to the ramp.
Since this is the 1st time I'm taking the drive off - like I said before I have never taken it out since I have had the boat - my bad.
Anyway, please point me to how to get the drive off and figure out what failed on it. I do have the manual, so I will get busy reading up 1st.
Thanks, Jeff
Thanks, Jeff
