Hi, <br /><br />I have a 2001 Glastron SX175... Volvo Penta 4.3 GL/Gi, 190hp.<br /><br />Was working fine last summer, then it got hot and we replaced the impeller. Worked fine another 5/6 outings. <br />Then (on my birthday of all days) it wouldn't start. It'd crank, but not start. The battery is good. <br />We thought that it wasn't getting compression, so we tore it down to check the heads and they were fine (according to a mechanic). Replaced all of the gaskets and made sure everything is torqued properly. <br />Now when I am trying to start it gives me....you guessed it... the same thing as before we did all of that work! <br /><br />I've had a mechanic come by and look at it a few days ago and he's been by a couple time since. He set the timing and it didn't help. Said it might be the ignition module, so I had it tested and it was bad, but when we put the new one on it still acts the same. The mechanic says that he thinks it's something small at this point, as he's had the head covers off and checked the rocker arms and stuff in there. It's getting fire, but won't start up. <br />I wasn't in Sunday, but he said that after initially setting the timing it started right up and he ran it for about 20 minutes and it was even fairly smoothe running considering that it had been sitting. But we haven't been able to start it again. <br /><br />If you can suggest what I might be able to do to get it running I'd appreciate it greatly. Summer is almost here in Texas!<br />Thanks, Brian
