Celtichawk
- May 6, 2012
- 564
Okay everyone got the boat about ready to go, however, I'm lost for words. Of course not knowing when the last time this boat has ran I decided to try to test run it once. Well to my surprise or should I say no surprise given that its been sitting, no start up. It will turn over, I primed it with some gas in the carb but I do not get even a slight go. Which led me to believe I wasn't getting spark. So I pulled the spark plug wire without the plug held it against the block of the motor and nothing. No spark! . I also tried testing with test light still nothing. I will need to get the right socket to pull the plugs. I thought I had it but appears to be missing. Hmmm..... odd because that is a very usable socket.
Anyways, what type of things should I be looking for and what items should be tested, along with how to test the items. It will turn over, but I believe there is no spark. Thanks. Any more info you need let me know I will provide it.
Also, can someone provide me the firing order for this motor? It might be that the Original Owner placed wires in wrong spot. I noticed they were labled but I do not know which cylinder is which.
1982 Volvo Penta I/O 270
