I have a 97 four winns 180 horizon. I have never owned a boat with the volvo penta outdrive on it. with the outdrive shift lever in the neutral position, the prop has quite a bit of resistance when turned by hand. (the prop does not have any free spin when spun fast by hand) is this normal for this type of outdrive, or do I have a slight lower unit problem in this outdrive.
Thank you for all the help.
