Hi Guys ,
I followed a thread found on here yesterday and managed to isolate my issue and get my friends boat running. The problem is that the relay for the electric fuel pump is not coming on. The power from the alternator to activate the relays winding is not giving anything on the relay side. The alternator is putting 12-13v from the green wire so at this point I can only imagine its the diode between ....
thread followed to isolate my problem...
http://forums.iboats.com/showthread.php?t=297584&fb_source=message
Thanks Don BTW !
In the mean time I rigged up a little jumper with a switch to allow him to start the pump manually by jumping current at the relays socket.
Thanks Don BTW !
