Assuming you mean helmet not helm. Did you remove the two screws and pull the steering pin out of the helmet?
The pin (#2 in picture below) is what those two bolts (#1) were holding in. Get yourself a couple of 1/4-20 bolts about 1.5" long and screw them into the threaded holes of the pin and use as jack screws to pull the pin out.
