Franky4Boats
- May 29, 2012
- 12
I had a heating problem but only over 1500, checked everything in the boat. Eventually pulled her and ran water from the Raw Water Pump out through the outdrive and saw water coming from the drive above the exhaust bellows where the water line seems to attach to the drive.
Diagnosis Q's
1. Is water oly supposed to come from the little holes on the sides above the prop?
2. If water leaks from the area where the hose and the bellows connect to the drive does this mean that there is a hole in the line?
3. Would that cause air bubbles or restrict water flow to the motor?
Repair Q's
1. If so can these be changed without having to pull the drive? Can I get to it if I pull the drive?
2. Cylinders are off and it goes pretty far up, the bellows at the drive doesnt seem to have a hose clamp like the boat side?
3. If i have to pull the drive will I also have to pull the collar and what tools would I need to get the collar off?
Diagnosis Q's
Repair Q's
