I have a 2008 volvo penta 5.7 gxi-j with a dps-a outdrive. The serial # of the engine is 4012226841 and the outdrive is 4151168134. one of the 4 hydraulic hoses fittings broke at the pump and needs to be replaced. After looking at the online seloc manual it is not clear exactly how the hose is removed from the pump. There is a retaining plate and 2 screws that need to be removed but I read on another post about someone removing the plate and the pump inside the housing dropping down inside the housing and making it unable to line up the screw holes again. In that post it said that the retaining plate did not have to be removed all the way but just loosened. After loosening the plate it looks like the hose fitting go directly into the pump without any type of screw fitting but i am not able to pull them out.
If anyone has replaced these or has any suggestions it would be greatly appreciated.
