I have a 2001 four winns 260 horizon with a 8.1 volvo duo prop. This past weekend I went out for the first time and it started off the trailer fine and we ran around for a bit then anchored in a cove. when we went to leave it was dead. Nothing when i turned the key to start. I jumped across the starter with the key on and it started fine. I used a light and checked when the key was turned to start and I have power coming from the key. I thought it may be the neutral saftey switch so I wired the the 2 wires together and still nothing. I assume it is the starter/solenoid but I wanted to check with someone else before I remove the started as it is not easy to get to.
Thank you in advance for any advise/help
