Re: Volvo Penta 270 outdrive lock mechanisim will not release when trimming motor up.
My last boat, the part Don is refuring to was damaged, I made one out of stainless steel, and it worked fine. I have to say though it was a bit tricky getting the shaft back in, and ajusted right. Also you have tilt ONLY, no trim. The unit must be all the way down, when you apply power, or you will be pulling your wallet out for more parts.
