Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
volvo penta aq125 parts diagram
  • volvo penta aq125 parts diagram
    I just bought a SELOC repair manual and it doesn't have a parts list or parts id #. I'm looking for a replacement part for the strainer for the top of the heat exchanger. Can someone tell me how to get this part or send a diagram of what this area looks like? VOLVO PENTA AQ125 270 Thank You!
    Re: volvo penta aq125 parts diagram
    If you have a Volvo repair shop you can order can order a new one but it will cost you somewhere around $$ 175.00 $$ .I was lucky enough to have the guy at the marina sell me a used one for $75. I have seen them on ebay.com every so often as well.Check under Boat parts and then go under Volvo penta.
    • #3
      Looks like we have the same engine.
      • #4
        Do you have an AQ125 A or B?
        Don S.
        Please, no PM's (Private Messages) regarding boat/engine problems.
        That is what the forums are for.
        Only forum/moderator issues will be answered in PM's.
        • #5
          Sorry! but its a VOLVO-PENTA AQ125A 270. I was able to find the strainer housing part #831909 but i still need some type of diagram or picture that shows how everything bolts together.
          • #6
            SAMAGEE, Can you take a pic of that area and email it to me? (smeach860@yahoo.com)I greatly appreciate your help.
            • #7
              Go to the link below. Then click on heat exchanger.It's for a 125B, but that part is the same as an A model. http://dougrussell.com/partscatalog/...GroupList=1860
              Don S.
              • #8
                Hey Pin I just replaced the strainer housing on an AQ125A motor.Maybe I can help you through this job.The picture doesn't show it but there are two flanges (I think 3/4 inch)that run to the housing.They both have O-rings(#13)Yes you will need TWO of them.Then you will need a sealing ring(#10)As you can see the diagram shows #10 slides over the spacer sleeve (#11).Now this is what to do.First,Slide #10 over #11. Now apply some dish soap for lubrication on to #10 sealing ring.Now try to slide housing onto #10.(I had to wiggle it back and forth).You will need the housing to get flush to the exchanger cover for a proper fit.When thats done be sure everything else that needs connected is lined up.You will see what I mean! Dont forget to use those #13 o-rings.Use gasket sealant to help from leaking on both 3/4 pipe flanges on the water line.This is a winded reply but it will save you a lot of grief.
                • #9
                  I'm waiting for the parts to arrive. you've all been very helpful.THANK YOU!!
