Boat was an original 5.0 GXI. Installed a new 5.7L Gxi Had PCM flashed from Volvo.
Engine will idle normal for about 30 seconds, then iac open up and stalls, will restart and stall after 2 seconds of running. No trouble codes, all sensors working in normal parameters, ect ok,tps ok,no knock sensor sensed, checked for vacuum leaks none, It still says 5.0l on engine size on parameters. When you get the engine past the idle stage it runs perfect, great power, no ping, no codes etc. Has anyone ever ran into this problem?
