I just bought a used 1998 Glastron with a Volvo Penta 3.0 L/Cobra SX sterndrive. It has a rough idle at 700 RPM's but idles higher and a little smoother at around 1000 RPM's once warm. The whole boat shakes. It has a Hustler 14.25 x 21 3-blade prop with barely a scratch on it. The boat was hitting 4100 RPM's and 36 mph with two people at WOT half trim (as high as the prop would allow without spitting up water) when I bought it. It also had/has a very poor hole shot. Since then, I ever so slightly advanced the timing on the distributor, sprayed out the carb with a whole bottle of cleaner, changed the fuel filter by the fuel pump, changed the plugs (Autolite AP104 set to 0.045 - please let me know if this is a problem - I got the x-ref on sparkplugs.com), and added fuel injector/carb cleaner to the gas. I adjusted the idle screws but cannot get rid of the 1-2 inches back and forth shaking of the engine whether it is cold or warm. The distributor cap and wires LOOK great, and the guy I got it from said they were replaced this year and he is a mechanic. The boat always starts right up and planes in about 6 seconds without a skiier with very little lifting of the bow. I should mention it has a doelfin. The boat pulls very hard in either direction. There's that little metal fin on the back on the motor that I cannot loosen to adjust, but that is quite crooked by about an inch.<br /><br />The problem is that it cannot pull up a skier above 200 lbs and pulls me up on slalom (185lb) only after drinking half the lake 30 seconds later.<br />I read that these can cause poor acceleration while towing:<br />-exhaust clogged with flapper<br />-base timing off<br />-bad plugs<br />-advance timing off (is this setting the gap?)<br />-motor height is too low (flat plate should be 1-2 inches above bottom of hull.)<br />-clogged fuel filter (by fuel pump)<br />-clogged fuel filter (in/by carburetor) what wrenches loosen this nut?<br />-prop pitch is too high or not enough blades<br /><br />Is 37 mph and 4200 RPM's typical for this boat, or what should I be seeing? Should I focus on engine tuning/troubleshooting like the things in the list above, or is this all the power I can get and I should just get a different prop (an 18" pitch 4-blade or a 19" pitch high five)?
